Menus escondidos no computador de bordo
Mensagempor mtedesco » 20 Dez 2013, 20:32
Pessoal,
achei essa informação, gostaria de compartilhar. No meu caso funcionou.
Serve para acessar as informações "escondidas" no computador de bordo, tais como velocidade real, pressão de combustível e várias outras listadas abaixo... Se alguém quiser tradução é só falar. Achei um vídeo tb explicando como faz se não entender a sequência abaixo. http://www.youtube.com/watch?v=9oSdk8WGTKw
Instructions for accessing the 'secret' menu options:
1. Hold down the 'day trip reset button' (I think??)
2. Insert key fob into slot (puts car in standby mode??)
3. Repeatedly press the reset button until you reach menu option 19 (Lock/Unlock)
4. Wait a moment for the option to be selected
5. Add the last 5 or 6 digits from you VIN (maybe chassis # ?)and enter that sum by repeatedly pressing the reset button (more on this later)
6. Additional options should be accessible until key fob is removed
A note about point #5: This caused confusion and was clarified later in the original thread, so I will give an example:
-The last five digits of the VIN are for example '63081' 6+3+0+8+1=18. -Therefore you will need to press the button 18 times in quick succession and then wait a moment for the value to be accepted.
Now if this works as described the following options will be available (Note: each option may have several sub-options):
1. VIN (?) or chassis number
2. Test 'combination display' (instrument panel or multi function disp? not sure)
3. Unused
4. Fuel usage, current (MPG ect.)
5. Fuel usage, average (range?)
6. Fuel level (left tank, right tank, total ect.)
7. Real time data (coolant temp, exterior temp, RPM, speed)
8. Speed data (actual speed, displayed speed, various avg speeds)
9. Current voltage
10. Distance/week (?? not sure on this one)
11. Units used in display (kilometers/miles, liters/gallons perhaps?)
12. Speed on arrival???? (don't ask, I have no idea)
13. test sounds for the 'comb. disp'(warning chimes ect)
14. Error code log
15. Ports ?
16. ? Unknown, though one of the entries apparently displays/ controls the value for the adaptive headlights
17. ? Unknown but may display heater info
18. Test warnings on 'comb. disp'
19. Lock on/off (as discussed above, this is where you get access to all these menus.)
20. Corrections?? (not sure)
21. Reset 'Combination Display'
Mauricio T.
'11 Black 130i
mtedesco
Re: Menus escondidos no computador de bordo
Mensagempor iaragao » 16 Jun 2014, 19:38
Traduz ae amigao......
118i
E87
09/10
iaragao
Registrado em: 08 Jun 2014, 12:50
Mensagempor loudenvier » 16 Jun 2014, 23:12
Já utilizei algumas vezes, mas não tem tanta utilidade assim... a velocidade digital é bem legal se quiser tomar um 0-100... e as temperaturas de óleo, etc.
Mensagempor PilotMartyMcFly » 17 Jun 2014, 14:08
Bacana. Alguém já testou nos novos modelos?
Eu acho a quantidade de informações no painel dos modelos novos muito fraca. Nem temperatura de óleo, água, nada. Já que a informação está disponível, se a BMW explorasse esse tipo de recurso de disponibilizasse para todo de forma "padrão", ela entregaria um veículo bem mais completo.
Se a informação já está ali, não entendo pq ela cria tanta dificuldade. Bastaria inserir isso no computador de bordo.
118 2014
PilotMartyMcFly
