Customized Non Woven Material
Mensagempor dfgcbc » 18 Mar 2020, 00:10
Quick Details
Place of Origin: Guangdong, China (Mainland)
Brand Name: Yi-Liang
Model Number: YL-NL
Material: nylon wheel /non woven wheel
Usage: satin flap wheel
Abrasive Grain Sizes: 60# 80# 120# 180# 320#
Application to: jewelry, ornaments, or precise metal products polishing and grinding.
Color: gray, green, red, brown
Metal polishing flap wheels: buffing aluminum,tableware, knife
Flap wheel with shaft: buffing stainless steel
Non woven flap wheel: buffing metal,watch
Abasive flap wheel: buffing polishing copper, brass.
Supply Ability: 10000 Unit/Units per Month
Packaging & Delivery
Packaging Details: General export packing
Port: Guangzhou Huangpu
Lead Time: Within 25days
Specifications
1.240 grit flap polish buff
2.For stainless steel and hard metal surface polishing
3.With good polishing power, flexible
240 grit flap polish buff for aluminum hoods and cookware
Product Description
1.Material: Non woven, sponge fiber materials.
2.Sizes: Diameter: 6 inch to 16 inch; Grand: 60 grit to 400 grit .( Size can be customized as your request !)
3.Color: Brown, gray(black), white, red, green
3-1) Non woven Flap Wheel
Non-woven surface finishing flap wheels are an ideal choice for a wide variety of blending and finishing applications common in the metal fabrication, welding and polishing industries.
3-2) Flap wheel with sanding paper
●Cleaning threaded parts
●Removing oxide from printed circuit boards
●De-glossing plastic parts
●Producing uniform finishes on aluminum, brass and stainless steel
●Interleaf flap wheels consist of alternating flaps of aluminum oxide coated abrasive cloth and medium grit material
●The interleaf product is less conformable than a standard flap wheel and will remove more material.
Made with High Quality sponge material!
Non-woven wheels have an open mesh construction that is waterproof, washable, conformable and non-loading.
Applications:Clean and remove imperfections on metal surfaces, clean built-up residue, deburr or finish a variety of surfaces, blend weld seams or create decorative finishes. Non-woven surface finishing products have excellent versatility.
Abrasive Grain:Aluminum Oxide, Silicon Carbide
Extra Coarse (XC), Coarse (C), Medium (M), Very Fine (VF),
Non woven wheel have characteristics with flexibility and grain distributed on non woven fabrics. It is suitable for imtermediate polishing operation between abrasive tools and buff.
Please contact us for more information.
●Deburring for Aluminium and Stainless Steel products
●Light grinding to achieve Satin Finish
●1,500 rpm polishing speed
●Grease-impregnated type available
●Available grits: Coarse, Medium, Fine, Very Fine, Super Fine, Ultra Fine
●3 types of wheels available (Laminated type, Spiral type, flap type)
●Wide range of sizes available (May require flanges for some size
Company Information
We Guangzhou Yi-Liang Polishing Trading Co.Ltd. are qualified manufacturer and trader of all kinds of industrial polishing and grinding machine and polishing materials(sanding belt--buffing wheel--metal polishing wheel--jewelry grinding wheel--working glove--polishing compound--flap wheel, etc.)
●Experience: With 6 years polishing experience and technique, involved in Dinner ware Polishing Production Line, Hinge production line, Alloy and hardware polishing production Line, Cast tube machinery, Furniture Polishing, etc.
●Customization: All specification can be customized as your request.
●Belief: Customers grow with us & maximizing your productivity at lowest cost. 10 inch flap buff wheels for zinc abrasive
●Certification: Verified By Onsite Checked of Alibaba.com
240 grit flap polish buff for aluminum hoods and cookwareCustomized Non Woven Material
website:http://www.ylpolishing.com/non-woven-material/
dfgcbc
Registrado em: 17 Mar 2020, 23:58
Voltar para Veículos BMW
