A4 Paper Sheeting And Packing Machine suppliers
Mensagempor dfgcbc » 18 Mar 2020, 00:07
Features:
This A4 Size Paper Cutting and Packing Machine is one of most advanced type of A4 paper production line in the world, it adopts the latest technologies in the similar paper converting equipment in Europe, uses world famous brand electric components.
Technical Specifications:
Our plant view:
Packing And Shipping:
Clients and Exhibition:
The pH of printing paper is also particular about it?
Acidic paper uses a mixture of wood pulp and straw pulp, and in order to save fiber consumption, talc powder and aluminum sulfate are used as fillers: straw pulp fibers are shorter, so dust is easily generated; and talc particles are large and hard. The pulp fiber has poor bonding force, causing the paper powder to fall off and wear the copying machine. In addition, since aluminum sulfate is corrosive in combination with water molecules in the air to produce acid, it is easy to make the paper capacity become brittle and yellow, which is not conducive to long-term preservation, and it is easy to generate acidic steam in the equipment through high temperature, which not only corrodes equipment but also harms human health.
Standard introduction
The specification of the paper means that after the paper is made, it is trimmed and cut into one.
The size is fixed. In the past, how many "open" (such as 8 or 16 open, etc.) to indicate the size of the paper, nowadays China adopts international standards, and the papers are marked with A0, A1, A2, B1, B2, etc. The format of the format. The standard specifies that the paper's width (indicated by X) and length (indicated by Y) are proportional to X:Y=1:n.
According to the basic area of the paper web, the format of the web is divided into A series, B series and C series. The web size of the format A0 is: 841mm 脳 1189mm, the web area is 1 square meter; the size of B0 is 1000mm 脳 1414mm; C0 has a web size of 917 mm 脳 1297 mm and a web area of 1.2 m 2 ; the format of the copy paper is only A series and B series. If the A0 paper is divided into two equal parts along the length, it will become the A1 specification, and the A1 paper will be turned in the length direction, and it will become the A2 specification, so it will be opened to the A8 specification; the B0 paper will also be opened to the B8 according to this method. specification. The web sizes of A0 to A8 and B0 to B8 are listed in the table below. Among them, A3, A4, A5, A6 and B4, B5, B6 are the specifications commonly used for copy paper.
Many countries use the ISO 216 international standard to define the size of paper, which is derived from Germany.
Passed in 1922, defined A, B, C three sets of paper size, including the well-known A4 paper size,
Group C paper sizes are primarily used for envelopes.
In addition, there are many non-standard sizes in China, such as the business acceptance registration form used by companies such as China Mobile, the size is 190mm*265mm, and it is easy to make mistakes when the copier is automatically selected.A4 Paper Sheeting And Packing Machine suppliers
website:http://www.papersheeter.com/a4-paper-sheeting-and-packing-machine/
dfgcbc
Registrado em: 17 Mar 2020, 23:58
Voltar para Veículos BMW
Usuários navegando neste fórum: Google [Bot] e 17 visitantes
