Customized Piercing Keel
Mensagempor dfgcbc » 18 Mar 2020, 00:06
Introduction
38 traverse keel high-quality cold-rolled coil hot-dip galvanizing as raw material, using thin-walled steel cold-bending process, the main thickness is 0.5mm-1.5mm, separating keel-G to produce high quality, advanced technology, fully in line with national standards. Production of light steel keel, a full range, including all types of customized drawings according to customer requirements.
Feature
The selected raw materials are uniform, high strength and good rigidity, ensuring good construction performance of light steel keel.
Advantage
It has the characteristics of light weight, high strength, good fire resistance, strong versatility and convenient installation. It must be suitable for shockproof, dustproof, soundproof, sound absorbing, temperature and other functions, as well as short circuit construction time and easy deformation.
Process: Since the root of the partition is easily affected by moisture, deformation, mildew and other quality problems, the bottom of the partition needs to be a pillow base;
Application
It is a new type of building materials. With the development of China's modernization, it has been widely used in hotels, airport lounges, passenger stations, railway stations, cinemas, shopping malls, factories and offices in recent years. Buildings, building renovations, old building interiors, ceilings.
Packaging And ShippingCustomized Piercing Keel
website:http://www.hs-qglg.com/partition-keel/piercing-keel/
dfgcbc
Registrado em: 17 Mar 2020, 23:58
Voltar para Veículos BMW
