BMW ENET CABLE e BMW E-SYS
Re: BMW ENET CABLE e BMW E-SYS
Mensagempor gutobridi » 10 Jan 2015, 12:15
Segue minha contribuição, mais mastigado que isso impossível, foi os passos que usei pra codificar o meu carro e deu tudo certo, são os softwares mais atualizados até o momento, usei o PSdZData_Full!
Cabo utilizado:
http://www.uobd2.net/wholesale/bmw-enet ... eries.html
Bmw Coding Database
http://www.bmwcodingdatabase.com/
E-Sys (Includes E-Sys v.3.26.1 & E-Sys Launcher Premium 1.05 (w/ Builtin Token Generator) & Guides):
https://mega.co.nz/#!p5JijaKY!DrkkiLi9A ... x7Oz45jU14
* NOTE: If upgrading from a previous E-Sys version, first uninstall current E-Sys version via Windows Control Panel.
"E-Sys - Installation Instructions - v.8.pdf" (E-Sys Installation & Setup Guide):
https://mega.co.nz/#!soAxUYLa!xjC3U_gLN ... qKBaXuJHEI
v.54.2_PSdZData_Lite:
https://mega.co.nz/#F!dghFRQgY!79e-cyQ3sFVISPH02g6x4g
* NOTE: 54.2 PSdZData Lite Version has the SWFL files removed which are needed only for flashing new firmware onto ECU's, and ARE NOT needed at all for any coding, so you get a time and bandwidth friendly 6.4 Gb download instead of a 25.3 Gb download, and when extracted it is 9.4 Gb instead of 34.2 Gb, saving 24.8 Gb of Hard Drive space.
Or if you actually need the full version for Flashing:
v.54.2_PSdZData_Full:
https://mega.co.nz/#F!Zo4UCKrT!gq2ekXxtVsT7xZgf-7xE5g
* NOTE: 54.x PSdZData requires E-Sys 3.23.4 or higher version.
* NOTE: If upgrading from a previous PSdZData version, DELETE old PSdZData folder and REPLACE with new PSdZData folder (Do NOT copy (merge) new PSdZData folder on on top of old PSdZData folder).
* NOTE: Downloading files from MEGA is best accomplished by disabling any AntiVirus software, and using Chrome Browser with the MEGA Extension. Do NOT use Firefox. For muti-part .rar archives, you must download all parts, and then when finished, open only part1.rar, and it will automatically process all parts of the .rar archive.
Fonte: User: shawnsheridan | http://f30.bimmerpost.com/
gutobridi
Mensagempor FGIR » 21 Jan 2015, 15:26
Pessoal, fiz algumas alterações na minha 116i (velocimetro digital, sport+, ligar no eco pro, etc), tudo funcionando certinho. Entretanto o modulo FEM_BODY não consigo alterar, dá uma mensagem de erro. Meu carro passou por uma atualização de sistema em dezembro (as alterações que deram certo fiz hj), será essa atualização alterou algo no modulo FEM_BODY que o E-Sys não consegue alterar?
Estou utilizando o E-Sys 3.26.1 e o PSdZData 54.1.
Será que o problema é o PSdZData desatualizado?
Outra coisa, no tópico fala em um programa EDIABAS. Não recebi esse programa da pessoal que vendeu o cabo para mim. Precisa esse programa também para F20, ou basta o E-Sys e o PSdZData?
FGIR
Mensagempor gutobridi » 21 Jan 2015, 16:27
gutobridi
Mensagempor poffomarcos » 21 Jan 2015, 16:54
De inicio eu não iria fazer o coding. Abri os links dos tutoriais e pensei "tudo em inglês? vai dar merda hahaha" ia deixar quieto por medo, pois manjo o básico do básico de inglês. Já estava uns 4 meses me coçando pra fazer..
Agora voltei a ler o tópico e penso que não é o fim do mundo. Como falaram antes, depois que está habituado com o programa, aberto na frente, creio que vai ser só seguir as instruções.
Acabei de efetuar a compra do cabo pelo link do primeiro post. Já comecei a ler algo pra tentar me habituar com o conteúdo.
Quando for fazer, qualquer dúvida pergunto aos colegas aqui.
Agora penso que os Dvds que mandam junto, será que estão na ultima versão do programa? A minha 320 é uma 2013, será que vai servir ou eu já vou baixando os programas mais atuais?
Valeu
- Imagem
B͟M͟W͟ F30 - 320 GP
poffomarcos
Mensagempor Sandro Tannuri » 21 Jan 2015, 19:58
Voces que sabem fazer coding ficam mudando a toda hora as programações?
Se não ficam, vale mesmo a pena fazer voce mesmo ou é melhor pagar para quem faça e pronto?
Abraços,
Sandro Tannuri
F30 N55 2015
Sandro Tannuri
Mensagempor poffomarcos » 22 Jan 2015, 09:37
Acho que estou entendendo o procedimento, ACHO hahaha
Só tem umas coisas que não assimilei direito. Para eu fazer as alterações por exemplo, é tudo modificado dentro do programa E-Sys? tipo mudando de "desativado" e "ativado"?
Um exemplo. Para eu habilitar a configuração do sport+ eu apenas tenho que achar o caminho dentro dos códigos e mudar para "ativado".
Existe alguma lista com os caminhos para cada modificação? se foresse pdf aqui F30_Cheat_Sheet_xxxxx eu não entendi o caminho.
Desculpe tantas perguntas. Mas comecei a ler um pouco ontem apenas. Abraços
- Imagem
B͟M͟W͟ F30 - 320 GP
poffomarcos
Mensagempor FGIR » 22 Jan 2015, 10:19
Atualizei o PsDzdata para versão 54.2 e consegui alterar o módulo FEM_BODY. Então o segredo qdo a CSS atualiza os módulos do carro e pegar uma versão mais recente do PsDzdata e refazer as configurações. Tranquilo.
Andei olhando e aparentemente e possível ter acesso até no módulo de injeção. No meu caso que tenho o motor 1.6 configurado para 136cv não conseguiria alterar o arquivo correspondente ao mapa de injeção para o da 118i que tem 170cv (pegando o arquivo de uma 118i e gravando no meu carro - em tese substituindo um pelo outro via E-Sys)?
FGIR
Mensagempor poffomarcos » 22 Jan 2015, 17:45
- Imagem
B͟M͟W͟ F30 - 320 GP
poffomarcos
Mensagempor Gustavo-LEZA » 22 Jan 2015, 17:46
_______________________________
BMW - F30 - 328i Sport GP - 2013
Black Sapphire Metallic
Assembled in Regensburg - Germany
Gustavo-LEZA
Registrado em: 08 Jan 2014, 14:42
Mensagempor Gustavo-LEZA » 22 Jan 2015, 17:58
Gustavo-LEZA
